Date/Time: Wed, 27 Nov 2024 22:38:22 +0000
Graphic Issues/Request
View Count: 236
[2023-06-22 23:00:34]
C. Notes - Posts: 129
Having a few issues here and a request...
I am encountering an occasional stuttering of the chart. I'll be hovering and the chart will stutter in size.
My chart DOM column gets wonky at times - One column gets very large (attached image)
https://www.sierrachart.com/image.php?Image=1687474571821.png
When downsizing my charts I like to remove title bar and menu bar. This leaves me a sliver of a bar on top that I can double click to enlarge the chart - however that sliver is then gone and the only way back is to use restore. I have added restore to chart shortcuts however it would be way better if we could have that sliver remain when the chart is enlarged.
Thanks!
[2023-06-23 00:44:41]
After more observation the sell column width is related to the chart stuttering.
[2023-06-23 09:04:18]
Sierra_Chart Engineering - Posts: 17198
We will provide no help with this whatsoever:
This is strictly an operating system issue and whatever issues you have with this, is your issue not ours.
Refer to the information here to adjust Chart DOM column widths:
Global Trade Settings Windows: Chart/Trade DOM Column Widths and Headers (Trade >> Customize Chart/Trade DOM Columns)
If you manually set the width of a particular column, it will remain. Otherwise the sizing will be automatic.
Date Time Of Last Edit: 2023-06-23 09:05:06
