Date/Time: Wed, 27 Nov 2024 22:45:03 +0000
buy low sell high
View Count: 364
[2023-06-22 16:41:11] |
VLiviu - Posts: 223 |
Hi all I am trying to accomplish an operation but doesnt work as I thought so :) I've attached a screenshoot. Well, this is is: - say I opened long but the price went against me, under my entry point so I buy a contract under the entry point and sell after a few ticks/pips upper (still under the entry point or higher) If I am doing so, when I hit sell, SC sells from the brakets order, not the one I just bought under the entry price. Can it be done? Thanks |
Buy_Sell.png / V - Attached On 2023-06-22 16:41:03 UTC - Size: 60.84 KB - 97 views |
[2023-06-23 19:12:09] |
Sierra_Chart Engineering - Posts: 17198 |
Not really fully understanding this, if at all but make sure you are not using Scale In functionality: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-23 19:12:20
[2023-06-23 20:24:25] |
Thank you! Let me explain again, please, this is important for me to understand (attached a new pic) The pic shows: 1) entered long 2) price lowered against me si I hit Buy (buy 1) 3) initial entry changed, lowered 4) hit buy again (buy 2) 5) price went up a tick and clicked Sell So, after I hit Sell, 1 contract sold from initial position (see the red line) , not from Buy 2 entry. Is it possible to for me to change any setting to make this work? Appreciate it! |
Buy_Sell2.png / V - Attached On 2023-06-23 20:24:18 UTC - Size: 297.38 KB - 77 views |
[2023-06-24 09:56:06] |
We still do not understand this. Maybe a user can help you. If you are asking about how order fills are matched, refer to: Trade Activity Log: Order Fill Matching and Flat to Flat Definition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-24 09:59:08] |
OK, thank you for your effort!
[2023-06-24 10:00:33] |
Maybe this is the answer: Order fills are always matched using a First in First Out matching method unless Chart >> Chart Settings >> Trading >> Use Last In First Out Fill Matching is enabled. or: Use Last In First Out Fill Matching will test, thanks for the documentation link. Date Time Of Last Edit: 2023-06-24 10:04:55
[2023-06-24 10:26:12] |
"Use Last In First Out Fill Matching" helped me to fix what I wanted. thanks :)) |
