Date/Time: Wed, 27 Nov 2024 23:30:09 +0000
future and stock data on different computer
View Count: 240
[2023-06-22 14:40:10] |
User887126 - Posts: 66 |
Hi, I did not find clear answer to my issue in the forum. I currently only have 1 sierra chart account and am currently using it for future in one of my pc. I want to use my second pc to view only the NASDAQ stock data. do i need a separate sierra chart account or can i just use the same one i have and just buy the nasdaq feed? please advise. |
[2023-06-22 15:46:52] |
Sierra_Chart Engineering - Posts: 17198 |
You can do what you want with a single Sierra Chart account. You can get real-time futures on one computer and real-time stocks on another computer. Since these are different exchanges. More information: Denali Exchange Data Feed: Connections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
