Date/Time: Wed, 27 Nov 2024 23:36:36 +0000
Anchored VWAP
View Count: 363
[2023-06-22 13:37:33]
Steve Leon - Posts: 301
Do you have any suggestions on hoe to create an anchored VWAP ?
For example if I want to have VWAP at a session start ? I have been creating a separate chart and then using study price overlay to reference it ? Is a way to do this directly wqithout study price overlay.
The other issue is if i wanted to anchor vwap (high or low) to a specific point ?
Thank you
[2023-06-22 15:44:26]
Sierra_Chart Engineering - Posts: 17198
You could use the Volume by Price study for this:
Volume By Price Study: Manually Drawn Volume Profiles That Automatically Extend to the Last Bar
It can be set to display the VWAP:
Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines
