Date/Time: Wed, 27 Nov 2024 23:33:39 +0000
Trading Stocks with Sierra Order Entry/Broker
View Count: 304
[2023-06-22 13:34:10]
Steve Leon - Posts: 301
I understand that you dont make recommendations regarding brokers.
I just wanted to know if I elect to use your new NASDAQ TotalView and consolidated data to trade stocks what broker(s) do you suggest. More importantly my question is how do you perform the order entry with an associated broker. Can I enter orders directly on the Sierra DOM with a linked broker ? Do you have any plans of having Teto Oder routing type system for stocks ?
I am trying to compare what you are offering to Tradestation. Sounds like you have some advantages but not sure how the broker/order entry would work for this.
Thank you
SPL
[2023-06-22 15:42:58]
Sierra_Chart Engineering - Posts: 17198
In the case of stock trading the only broker that Sierra Chart works with is Interactive Brokers:
Interactive Brokers Trading Service
For information how to do this, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
