Date/Time: Wed, 27 Nov 2024 12:34:28 +0000
Connection error: Teton : Secondary instance not allowing connections to server
View Count: 510
[2023-06-22 07:24:02]
Judge Kilday - Posts: 21
Hi:
I have tried logging in and out several times and connecting/disconnecting from Teton data but I keep getting an error message.
Image of the error message is at this link:
https://www.sierrachart.com/image.php?Image=1687418459107.png
Am I properly connected to my data feed or not? What do I need to do?
imageScreenshot 2023-06-22 at 08.07.29.png / V - Attached On 2023-06-22 07:17:32 UTC - Size: 43.77 KB - 91 views
[2023-06-22 08:27:56]
Sierra_Chart Engineering - Posts: 17191
Disregard that.
See post 11:
Notice: Teton Internet Service Provider Issue
[2023-08-14 17:31:43]
User654138 - Posts: 27
I keep getting a secondary instance is blocking connection on my desktop. I have closed my laptop installation of sierra charts but I still keep getting that message, how do I correct this?
[2023-08-14 17:48:16]
I have logged in to all installations of sierra charts that I have and disconnected both of them but when I try to reconnect my primary installation I keep getting "another instance is blocking connection" message.
imageScreen Shot 2023-08-14 at 1.34.50 PM.png / V - Attached On 2023-08-14 17:47:11 UTC - Size: 416.7 KB - 75 views
[2023-08-14 19:41:53]
John - SC Support - Posts: 36309
You can ignore that message. You will be properly connected even with the message.
[2023-08-14 23:44:33]
I cannot get my desktop to connect, I keep getting the same error message. My laptop connects and disconnects no problem.
Date Time Of Last Edit: 2023-08-15 00:16:30
imageconnect.png / V - Attached On 2023-08-14 23:39:02 UTC - Size: 230.76 KB - 75 views
[2023-08-15 01:44:27]
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
