Date/Time: Wed, 27 Nov 2024 23:40:19 +0000
trial
View Count: 267
[2023-06-22 06:55:23]
brinjar - Posts: 23
HI i just opened up a siaerra chart account a few days ago . i found that there is somthing called free trial and i can active that from the global setting part via my phone number . are you sure trial is still accessible ? no sms has been sent to me . i can send my phone number to support if you want .
[2023-06-22 09:29:10]
Sierra_Chart Engineering - Posts: 17198
Your account has been activated and the usage time extended if necessary.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit".
To get started with Sierra Chart, follow the Sierra Chart setup instructions here:
Sierra Chart Setup Instructions 1
