Date/Time: Wed, 27 Nov 2024 23:47:08 +0000
copy drawings
View Count: 241
[2023-06-21 21:32:51] |
Bram - Posts: 25 |
dear Mr, Mrs, i have copied a chart from one og my chartbooks to another chartbook1, i want to copy drawings to other charts in the same chartbook1. I used chart settings/drawings/ and the numebr of the charts #1 (1). normaly this works byt now it doesn't, any idea whta the problem might be? many thanks in advance |
[2023-06-22 15:41:31] |
Sierra_Chart Engineering - Posts: 17198 |
Refer to the documentation here for this: Copying Chart Drawings from Other Charts Automatically And refer to: Chart Settings: What to Do If Chart Drawings Do Not Copy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
