Date/Time: Wed, 27 Nov 2024 23:26:51 +0000
Connection error: Not authorized
View Count: 279
[2023-06-21 21:09:45]
rpm300 - Posts: 1
I am receiving an error "Connection error: Not authorized" when I attempt to connect to Teton service. Below is my message log. Can you please assist?
Reading Internal Order ID file. | 2023-06-21 21:01:09.584
Reading Trade Orders file. | 2023-06-21 21:01:09.642
Reading Trade Positions file. | 2023-06-21 21:01:09.642
Reading Trade Account Data files. | 2023-06-21 21:01:09.642
Software version: 2504 64-bit | 2023-06-21 21:01:09.643
Primary Thread ID: 40936 | 2023-06-21 21:01:09.643
Usage end date: 2023-07-10 | 2023-06-21 21:01:09.643
Enabled for: Advanced Features 2. | 2023-06-21 21:01:09.643
Enabled for: Sierra Chart Historical Data Service. | 2023-06-21 21:01:09.643
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-06-21 21:01:09.643
Enabled for: Delayed Denali Exchange Data Feed. | 2023-06-21 21:01:09.643
Enabled for exchange2: CME | 2023-06-21 21:01:09.643
Enabled for exchange2: fairx_exchange.data | 2023-06-21 21:01:09.643
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-06-21 21:01:09.643
Current selected Data/Trading service: Teton CME Order Routing | 2023-06-21 21:01:09.643
Custom symbol settings values: enabled | 2023-06-21 21:01:09.643
Chart Update Interval: 500 | 2023-06-21 21:01:09.643
Intraday Data Storage Time Unit: 0 | 2023-06-21 21:01:09.643
Time Zone: +00:00:00 (UTC+00) | 2023-06-21 21:01:09.643
2023-06-21 21:01:09 Local computer time in UTC | 2023-06-21 21:01:09.643
2023-06-21 21:01:09 Local computer time in SC Time Zone | 2023-06-21 21:01:09.643
2023-06-21 21:01:09 Server time in UTC | 2023-06-21 21:01:09.643
Local computer UTC time and Server UTC time difference: 0 seconds. | 2023-06-21 21:01:09.643
Program path: C:\SierraChart\ | 2023-06-21 21:01:09.643
Data Files path: C:\SierraChart\Data\ | 2023-06-21 21:01:09.643
OS Version Number: 10.0 | 2023-06-21 21:01:09.644
Locale Setting: C | 2023-06-21 21:01:09.644
DLLs: UserContributedStudies_64.dll | 2023-06-21 21:01:09.644
Allowed protected custom studies: | 2023-06-21 21:01:09.644
Crash reporter started: true | 2023-06-21 21:01:09.644
Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-06-21 21:01:09.662
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 21:01:09.694
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-06-21 21:01:09.843
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-06-21 21:01:09.843
Received 5 login tokens. | 2023-06-21 21:01:10.150
Symbol settings MD5 received. Request ID: 1. | 2023-06-21 21:01:11.304
Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. | 2023-06-21 21:01:11.304
Requested user files to download. | 2023-06-21 21:01:12.149
Symbol settings received. Request ID: 2. | 2023-06-21 21:01:13.542
Teton CME Order Routing | Firm: Dorman | 2023-06-21 21:01:14.152
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 21:01:14.152
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 21:01:14.187
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 21:01:14.187
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2023-06-21 21:01:14.187
Teton CME Order Routing | Network connection to server complete. | 2023-06-21 21:01:14.243
Teton CME Order Routing | Starting socket receive thread. | 2023-06-21 21:01:14.243
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-06-21 21:01:14.243
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-06-21 21:01:14.411
Teton CME Order Routing | Sending logon request message. | 2023-06-21 21:01:14.411
Teton CME Order Routing | Received logon response. | 2023-06-21 21:01:14.466
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-06-21 21:01:14.466
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-06-21 21:01:14.466
Teton CME Order Routing | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-06-21 21:01:14.466
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 21:01:14.466
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:14.466
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-06-21 21:01:14.493
DTC Client socket (1) | CloseSocket call. | 2023-06-21 21:01:14.493
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 21:01:14.494
Teton CME Order Routing | Disconnected. | 2023-06-21 21:01:14.494
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:14.494
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-06-21 21:01:14.547
DTC Client socket (1) | Closed. | 2023-06-21 21:01:14.547
Teton CME Order Routing | Firm: Dorman | 2023-06-21 21:01:16.482
Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 21:01:16.482
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 21:01:16.482
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 21:01:16.482
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2023-06-21 21:01:16.482
Teton CME Order Routing | Network connection to server complete. | 2023-06-21 21:01:16.536
Teton CME Order Routing | Starting socket receive thread. | 2023-06-21 21:01:16.536
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-06-21 21:01:16.536
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-06-21 21:01:16.701
Teton CME Order Routing | Sending logon request message. | 2023-06-21 21:01:16.701
Teton CME Order Routing | Received logon response. | 2023-06-21 21:01:16.757
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-06-21 21:01:16.757
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-06-21 21:01:16.757
Teton CME Order Routing | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-06-21 21:01:16.757
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 21:01:16.757
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:16.757
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-06-21 21:01:16.762
DTC Client socket (1) | CloseSocket call. | 2023-06-21 21:01:16.763
Teton CME Order Routing | Disconnected. | 2023-06-21 21:01:16.763
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:16.763
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 21:01:16.763
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-06-21 21:01:16.816
DTC Client socket (1) | Closed. | 2023-06-21 21:01:16.816
Files to Open on Startup | File does not exist: C:\SierraChart\Data\- | 2023-06-21 21:01:17.375
Teton CME Order Routing | Firm: Dorman | 2023-06-21 21:01:18.766
Teton CME Order Routing | Connecting to the server futurestrading11.sierracharts.com. Port 11091 | 2023-06-21 21:01:18.766
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 21:01:18.766
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 21:01:18.766
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2023-06-21 21:01:18.766
Teton CME Order Routing | Network connection to server complete. | 2023-06-21 21:01:18.821
Teton CME Order Routing | Starting socket receive thread. | 2023-06-21 21:01:18.821
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-06-21 21:01:18.821
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-06-21 21:01:18.985
Teton CME Order Routing | Sending logon request message. | 2023-06-21 21:01:18.985
Teton CME Order Routing | Received logon response. | 2023-06-21 21:01:19.042
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-06-21 21:01:19.042
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-06-21 21:01:19.042
Teton CME Order Routing | Logon error received from server: Secondary instance is not allowing connections to this server | 2023-06-21 21:01:19.042
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 21:01:19.042
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:19.042
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-06-21 21:01:19.059
DTC Client socket (1) | CloseSocket call. | 2023-06-21 21:01:19.059
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 21:01:19.059
Teton CME Order Routing | Disconnected. | 2023-06-21 21:01:19.060
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:19.060
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-06-21 21:01:19.113
DTC Client socket (1) | Closed. | 2023-06-21 21:01:19.113
Teton CME Order Routing | Firm: Dorman | 2023-06-21 21:01:21.047
Teton CME Order Routing | Connecting to the server futurestrading12.sierracharts.com. Port 11090 | 2023-06-21 21:01:21.047
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 21:01:21.047
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 21:01:21.048
DTC Client socket (1) | Connecting to IP: 38.89.227.130. | 2023-06-21 21:01:21.048
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2023-06-21 21:01:42.079 *
DTC Client socket (1) | CloseSocket call. | 2023-06-21 21:01:42.079
DTC Client socket (1) | Closed. | 2023-06-21 21:01:42.079
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 21:01:42.079
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:42.079
DTC Client socket (0) | CloseSocket call. | 2023-06-21 21:01:42.094
Teton CME Order Routing | Disconnected. | 2023-06-21 21:01:42.095
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 21:01:42.095
Teton CME Order Routing | Firm: Dorman | 2023-06-21 21:01:44.085
Teton CME Order Routing | Connecting to the server futurestrading13.sierracharts.com. Port 11090 | 2023-06-21 21:01:44.085
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 21:01:44.088
DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 21:01:44.088
DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2023-06-21 21:01:44.088
Teton CME Order Routing | Network connection to server complete. | 2023-06-21 21:01:44.144
Teton CME Order Routing | Starting socket receive thread. | 2023-06-21 21:01:44.144
Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2023-06-21 21:01:44.144
Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2023-06-21 21:01:44.367
Teton CME Order Routing | Sending logon request message. | 2023-06-21 21:01:44.367
Teton CME Order Routing | Received logon response. | 2023-06-21 21:02:00.326
Teton CME Order Routing | Server Name: SC DTC Server. | 2023-06-21 21:02:00.326
Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2023-06-21 21:02:00.326
Teton CME Order Routing | Connection error: Not authorized | 2023-06-21 21:02:00.326 *
Teton CME Order Routing | Waiting for socket receive thread to end | 2023-06-21 21:02:00.337
DTC Client socket (1) | CloseSocket call. | 2023-06-21 21:02:00.338
Teton CME Order Routing | Disconnected. | 2023-06-21 21:02:00.338
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 21:02:00.338
DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-06-21 21:02:00.409
DTC Client socket (1) | Closed. | 2023-06-21 21:02:00.409
[2023-06-22 10:09:42]
Sierra_Chart Engineering - Posts: 17198
This should now be resolved. Let us know if you still have a problem connecting.
Date Time Of Last Edit: 2023-06-22 10:10:15
