Date/Time: Wed, 27 Nov 2024 23:31:32 +0000
Cannot connect to account
View Count: 249
[2023-06-21 20:45:55] |
FatTailHunter - Posts: 8 |
Hello, I am able to sign into my Sierra chart software and was trading live this morning with no problems. I hadn't even shut down the platform but while I was away from my screen I was disconnected from my data feed and cannot get it to reconnect. The bar in the left hand corner will just stay yellow. This is what my message log looks like, Created the DTC Protocol server. | 2023-06-21 15:28:37.353 DTC Protocol Server listening on port 11099. | 2023-06-21 15:28:37.356 Reading Internal Order ID file. | 2023-06-21 15:28:37.356 Reading Trade Orders file. | 2023-06-21 15:28:37.868 Reading Trade Positions file. | 2023-06-21 15:28:37.869 Reading Trade Account Data files. | 2023-06-21 15:28:37.870 Software version: 2459 64-bit | 2023-06-21 15:28:37.873 Primary Thread ID: 248 | 2023-06-21 15:28:37.873 Usage end date: 2023-07-01 | 2023-06-21 15:28:37.873 Enabled for: Advanced Features 2. | 2023-06-21 15:28:37.873 Enabled for: Sierra Chart Historical Data Service. | 2023-06-21 15:28:37.873 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-06-21 15:28:37.873 Enabled for: Delayed Denali Exchange Data Feed. | 2023-06-21 15:28:37.873 Enabled for exchange2: CME (Trading Account Required) | 2023-06-21 15:28:37.873 Enabled for exchange2: CBOT (Trading Account Required) | 2023-06-21 15:28:37.873 Enabled for exchange2: COMEX (Trading Account Required) | 2023-06-21 15:28:37.873 Enabled for exchange2: NYMEX (Trading Account Required) | 2023-06-21 15:28:37.873 Enabled for exchange2: fairx_exchange.data | 2023-06-21 15:28:37.873 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-06-21 15:28:37.873 Current selected Data/Trading service: Teton CME Order Routing | 2023-06-21 15:28:37.874 Custom symbol settings values: enabled | 2023-06-21 15:28:37.874 Chart Update Interval: 1000 | 2023-06-21 15:28:37.874 Intraday Data Storage Time Unit: 0 | 2023-06-21 15:28:37.874 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-06-21 15:28:37.874 2023-06-21 20:28:37 Local computer time in UTC | 2023-06-21 15:28:37.874 2023-06-21 15:28:37 Local computer time in SC Time Zone | 2023-06-21 15:28:37.874 2023-06-21 20:28:34 Server time in UTC | 2023-06-21 15:28:37.874 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-06-21 15:28:37.874 Program path: Y:\SierraChart\ | 2023-06-21 15:28:37.874 Data Files path: Y:\SierraChart\Data\ | 2023-06-21 15:28:37.874 OS Version Number: 10.0 | 2023-06-21 15:28:37.874 Locale Setting: C | 2023-06-21 15:28:37.874 DLLs: Test_64.dll, Tutorial1_64.dll, UserContributedStudies_64.dll | 2023-06-21 15:28:37.876 Allowed protected custom studies: | 2023-06-21 15:28:37.876 Crash reporter started: true | 2023-06-21 15:28:37.876 Created the DTC Protocol historical data server. | 2023-06-21 15:28:38.384 HD Server Manager | Listening on port 11098. | 2023-06-21 15:28:38.400 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2023-06-21 15:28:38.401 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-06-21 15:28:38.765 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-06-21 15:28:38.917 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-06-21 15:28:38.917 Received 5 login tokens. | 2023-06-21 15:28:39.035 Symbol settings MD5 received. Request ID: 1. | 2023-06-21 15:28:40.304 Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2023-06-21 15:28:40.304 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:28:45.170 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:28:45.171 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:28:45.324 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:28:45.325 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:28:45.325 Service is currently connecting. | 2023-06-21 15:28:46.751 * Service connection timed out. Will disconnect and retry. | 2023-06-21 15:29:45.171 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:29:45.171 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:29:45.171 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:29:45.185 DTC Client socket (1) | Closed. | 2023-06-21 15:29:45.186 Teton CME Order Routing | Disconnected. | 2023-06-21 15:29:45.186 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:29:45.187 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:29:47.188 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:29:47.188 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:29:47.190 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:29:47.191 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:29:47.191 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:30:47.190 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:30:47.190 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:30:47.190 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:30:47.201 Teton CME Order Routing | Disconnected. | 2023-06-21 15:30:47.201 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:30:47.201 DTC Client socket (1) | Closed. | 2023-06-21 15:30:47.202 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:30:49.203 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:30:49.203 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:30:49.205 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:30:49.205 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:30:49.205 File >> Disconnect selected. | 2023-06-21 15:30:59.987 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:30:59.987 Teton CME Order Routing | Disconnected. | 2023-06-21 15:30:59.987 DTC Client socket (1) | Closed. | 2023-06-21 15:30:59.988 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:31:04.758 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:31:04.758 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:31:04.759 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:31:04.760 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:31:04.760 Sierra Chart account data changed. Requesting updated account information. | 2023-06-21 15:31:35.862 Successfully processed Sierra Chart account data. | 2023-06-21 15:31:36.701 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:32:04.760 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:32:04.760 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:32:04.760 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:32:04.772 Teton CME Order Routing | Disconnected. | 2023-06-21 15:32:04.772 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:32:04.772 DTC Client socket (1) | Closed. | 2023-06-21 15:32:04.772 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:32:06.773 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:32:06.773 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:32:06.775 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:32:06.776 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:32:06.776 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:33:06.774 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:33:06.774 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:33:06.774 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:33:06.784 Teton CME Order Routing | Disconnected. | 2023-06-21 15:33:06.785 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:33:06.785 DTC Client socket (1) | Closed. | 2023-06-21 15:33:06.785 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:33:08.787 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:33:08.787 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:33:08.788 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:33:08.789 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:33:08.790 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:34:08.789 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:34:08.789 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:34:08.789 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:34:08.800 Teton CME Order Routing | Disconnected. | 2023-06-21 15:34:08.800 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:34:08.800 DTC Client socket (1) | Closed. | 2023-06-21 15:34:08.801 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:34:10.802 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:34:10.802 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:34:10.803 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:34:10.804 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:34:10.804 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:35:10.804 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:35:10.804 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:35:10.804 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:35:10.816 Teton CME Order Routing | Disconnected. | 2023-06-21 15:35:10.816 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:35:10.816 DTC Client socket (1) | Closed. | 2023-06-21 15:35:10.816 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:35:12.817 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:35:12.817 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:35:12.819 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:35:12.820 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:35:12.820 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:36:12.818 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:36:12.818 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:36:12.818 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:36:12.830 Teton CME Order Routing | Disconnected. | 2023-06-21 15:36:12.830 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:36:12.830 DTC Client socket (1) | Closed. | 2023-06-21 15:36:12.830 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:36:14.832 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:36:14.833 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:36:14.834 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:36:14.835 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:36:14.835 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:37:14.834 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:37:14.834 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:37:14.834 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:37:14.846 Teton CME Order Routing | Disconnected. | 2023-06-21 15:37:14.846 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:37:14.846 DTC Client socket (1) | Closed. | 2023-06-21 15:37:14.846 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:37:16.847 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:37:16.847 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:37:16.849 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:37:16.850 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:37:16.850 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:38:16.849 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:38:16.850 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:38:16.850 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:38:16.861 Teton CME Order Routing | Disconnected. | 2023-06-21 15:38:16.861 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:38:16.861 DTC Client socket (1) | Closed. | 2023-06-21 15:38:16.861 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:38:18.863 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:38:18.863 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:38:18.865 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:38:18.865 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:38:18.866 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:39:18.865 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:39:18.865 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:39:18.865 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:39:18.876 Teton CME Order Routing | Disconnected. | 2023-06-21 15:39:18.876 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:39:18.876 DTC Client socket (1) | Closed. | 2023-06-21 15:39:18.876 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:39:20.877 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:39:20.877 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:39:20.878 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:39:20.879 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:39:20.879 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:40:20.878 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:40:20.878 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:40:20.878 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:40:20.890 Teton CME Order Routing | Disconnected. | 2023-06-21 15:40:20.890 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:40:20.891 DTC Client socket (1) | Closed. | 2023-06-21 15:40:20.891 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:40:22.892 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:40:22.892 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:40:22.894 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:40:22.894 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:40:22.895 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:41:22.895 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:41:22.895 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:41:22.895 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:41:22.906 Teton CME Order Routing | Disconnected. | 2023-06-21 15:41:22.906 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:41:22.906 DTC Client socket (1) | Closed. | 2023-06-21 15:41:22.906 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:41:24.907 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:41:24.907 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:41:24.909 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:41:24.910 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:41:24.910 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:42:24.907 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:42:24.907 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:42:24.907 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:42:24.918 Teton CME Order Routing | Disconnected. | 2023-06-21 15:42:24.919 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:42:24.919 DTC Client socket (1) | Closed. | 2023-06-21 15:42:24.919 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:42:26.921 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:42:26.921 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:42:26.922 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:42:26.923 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:42:26.923 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:43:26.923 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:43:26.923 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:43:26.923 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:43:26.934 Teton CME Order Routing | Disconnected. | 2023-06-21 15:43:26.934 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:43:26.934 DTC Client socket (1) | Closed. | 2023-06-21 15:43:26.935 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:43:28.937 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:43:28.937 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:43:28.939 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:43:28.939 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:43:28.940 Service connection timed out. Will disconnect and retry. | 2023-06-21 15:44:28.938 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-06-21 15:44:28.938 Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:44:28.938 DTC Client socket (1) | CloseSocket call. | 2023-06-21 15:44:28.950 Teton CME Order Routing | Disconnected. | 2023-06-21 15:44:28.950 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-06-21 15:44:28.950 DTC Client socket (1) | Closed. | 2023-06-21 15:44:28.950 Teton CME Order Routing | Firm: Dorman | 2023-06-21 15:44:30.951 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2023-06-21 15:44:30.951 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2023-06-21 15:44:30.953 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-06-21 15:44:30.954 DTC Client socket (1) | Connecting to IP: 208.185.224.130. | 2023-06-21 15:44:30.954 . |
[2023-06-21 22:55:04] |
Sierra_Chart Engineering - Posts: 17198 |
Update Sierra Chart to the current version. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-21 22:55:11
