Date/Time: Wed, 27 Nov 2024 23:49:20 +0000
SPX Quote off
View Count: 297
[2023-06-21 19:44:56] |
User82146 - Posts: 5 |
Hi, I just noticed that SPX500 is quoting 5pts higher for me than ThinkorSwim. I'm not sure what is causing this discrepancy. Thanks |
[2023-06-22 10:08:34] |
Sierra_Chart Engineering - Posts: 17198 |
That is a CFD symbol. We cannot provide any help with that. It is what it is. Also be aware of the new NASDAQ Global Indexes data feed we have which has a symbol for the S&P 500. But the price is different than the one calculated by S&P but the overall trend is the same: https://www.sierrachart.com/index.php?page=doc/DenaliExchangeDataFeed.php#NASDAQGlobalIndexDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-22 10:09:12
