Date/Time: Wed, 27 Nov 2024 23:45:09 +0000
Market Thrust
View Count: 355
[2023-06-21 15:47:53] |
User928353 - Posts: 8 |
Hi I am looking for this indicator its based on Market stats the description is as follows Market Thrust Probably the best alternative to the Arms Index is the market thrust indicator. Its formula is as follows: (Advancing Issues x Advancing Volume) - (Declining Issues x Declining Volume) With the market thrust indicator, the more advancing issues, the larger the market thrust value. Similarly, the more advancing volume, the larger the market thrust value. Read more at: https://commodity.com/technical-analysis/arms-index-trin/ Thank you |
[2023-06-22 09:39:12] |
Sierra_Chart Engineering - Posts: 17198 |
You can construct this using the Sierra Chart Market Statistics: Sierra Chart Market Statistics And custom formula symbols: Custom Calculated Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
