Date/Time: Wed, 27 Nov 2024 23:48:11 +0000
Replay data different than Denali feed
View Count: 283
[2023-06-20 21:45:43]
PhiX - Posts: 36
I have a custom indicator that plots a bubble on a candle (ES) to indicate a "sweep order".
The setting is to display sweep orders of >100.
When I replay using Accurate Trading System Back Test it works properly...displaying all sweep orders >100.
With the real time Denali feed it only displays sweep orders over 500 which makes no sense to me.
I let it run today with the Denali feed and there were zero sweep orders. When replayed there were about a dozen.
I have checked all my data and market depth settings and can't figure out why this is happening.
The chart is just a basic chart with no other indicators installed.
It doesn't matter what time frame or tick or volume chart is used.
Any help is appreciated.
Date Time Of Last Edit: 2023-06-20 22:13:25
[2023-06-21 01:58:48]
Sierra_Chart Engineering - Posts: 17198
The only thing we can say to check is set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
Otherwise, we cannot possibly know what the reason is in your particular case. This is not within the scope of our support if it involves a custom study.
[2023-06-21 10:33:14]
PhiX - Posts: 36
It has always been set for 1 tick.
Can you confirm there is absolutely zero difference in the live Denali feed vs. the data when replayed?
[2023-06-21 14:12:19]
Yes zero difference.
