Date/Time: Wed, 27 Nov 2024 23:23:46 +0000
Cannot Replay Market Stat
View Count: 250
[2023-06-20 14:16:21] |
maxpi - Posts: 181 |
I have an intraday chart of the ADR-SP[M]. I can replay data of last Friday and previous to that, cannot replay Monday's or today's data. I'm guessing that the new holiday has caused a problem of some sort. Replaying a futs symbol works fine, as always...
[2023-06-21 13:37:56] |
Today i'm picking a random market stat symbol, ISS-SP[M], one that I've never downloaded the data before... I open the intraday chart, attempt replay: Standard Replay, Speed = 1, Single Chart, Use Start Date-Time = 2023-06-20, 09:30:00, Start Paused unchecked. The chart jumps to the last bar of Friday 2023-06-16 and does nothing. If I leave Use Start Date Time unchecked and back the chart up the replay will start.
[2023-06-21 13:48:29] |
Sierra_Chart Engineering - Posts: 17198 |
We see no problem doing the replay you describe. Do you see this Date-Time in the chart: 2023-06-20, 09:30:00,
[2023-06-21 13:58:54] |
I see that date when no replay is enacted.... it started working now, nothing changed here but it's now working. Thanks. When it was failing it would jump to the last bar of Friday rather than the first bar of the replay period.
Date Time Of Last Edit: 2023-06-21 14:15:42
