Date/Time: Wed, 27 Nov 2024 23:39:15 +0000
Symbol Settings - Multiple Matches - Priority?
View Count: 264
[2023-06-20 10:52:14] |
BlakJak - Posts: 108 |
I want some custom settings applied to all my NQTV symbols so I configured a ~-NQTV "symbol setting" and set my desired custom options. I find that my settings are not getting applied as the settings in the already existing stock symbol setting (e.g. AAPL-NQTV) are overriding it. How can I get my wildcard to take priority over the individual stock settings? |
[2023-06-21 14:18:38] |
Sierra_Chart Engineering - Posts: 17198 |
I find that my settings are not getting applied as the settings in the already existing stock symbol setting (e.g. AAPL-NQTV) are overriding it. Yes this is true.How can I get my wildcard to take priority over the individual stock settings? Global Symbol Settings: Direct Editing of Global Symbol Settings through Underlying File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-21 14:26:47] |
Thanks. This is what I did eventually as a workaround hoping there was a better solution. My concern is that any update will overwrite the settings. I suppose I could copy the settings into the CustomSymbolSettings xml file. Would that make it permanent? |
[2023-06-21 14:40:54] |
No there is no better solution. I suppose I could copy the settings into the CustomSymbolSettings xml file. Would that make it permanent? Yes.
