Date/Time: Sat, 19 Sep 2026 01:52:46 +0000
[Programming Help] - Recalculating sc.SimpleMovAvg() within manual loop.
View Count: 655
[2023-06-20 09:54:43]
User92573 - Posts: 614
Dear Support Board
Any help or direction gratefully received.
I'm simply trying to recalculate the sc.SimpleMovAvg() array following an event/change in data.
int Current_Index = sc.Index;
On Event
Input_SMA_Length.SetInt(10)
// Now iterate through the sc.SimpleMovAvg() array an update the data/values
for (int i_Index = 0; i_Index <= Current_Index; ++i_Index)
sc.SimpleMovAvg(sc.BaseData[SC_LAST][i_Index], Subgraph_SimpleMA[i_Index], Input_SMA_Length.GetInt());
The rror message is "cannot convert argument 1 from 'float' to 'SCFloatArrayRef'"
As I'm learning ACSIL this has me a little stumped so any help or direction appreciated.
Many thanks.
[2023-06-20 11:03:34]
User431178 - Posts: 906
First and second arguments are SCFloatArrayRef, you are passing in the float value at i_Index for each.
Indexing is controlled by the third argument, as function requires 4 arguments with manual looping.
SCFloatArrayRef SimpleMovAvg(SCFloatArrayRef FloatArrayIn, SCFloatArrayRef FloatArrayOut, int Index, int Length);
On Event
sc.SimpleMovAvg(sc.BaseData[SC_LAST], Subgraph_SimpleMA, i_Index, Input_SMA_Length.GetInt());
[2023-06-20 14:51:19]
User431178
Thank you so much.
I'd have struggled to find that.
Many thanks
