Date/Time: Wed, 27 Nov 2024 23:45:16 +0000
Purchase additional historical market depth data
View Count: 239
[2023-06-19 22:22:29] |
User262131 - Posts: 5 |
Hi, I know historical market depth data is limited to 15 days back. Is there any way to purchase more historical data for backtesting purposes? I am looking for a year or two of a few futures markets. Thank you. |
[2023-06-20 11:00:07] |
Sierra_Chart Engineering - Posts: 17198 |
The amount of historical market depth data depends upon the symbol. There is more data available than this. You need to follow the instructions here: Market Depth Historical Graph: Downloading Of Historical Market Depth Data You will be able to access all of it. We do not maintain anything more than what a user can access. It is deleted because it takes so much space. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-21 13:00:38] |
Thank you. I found what I was doing wrong, I was trying to load much older data on a chart using continuous contracts for futures assuming it would load the historical depth for each past contract. If I manually changed the chart to the older contracts I was then able to get more historical data. |
[2023-06-21 13:11:20] |
Yes that probably does make sense.
