Date/Time: Wed, 27 Nov 2024 22:26:39 +0000
[Programming Help] - Sierra’s Trading System – Study graph crossover
View Count: 578
[2023-06-19 15:57:34]
User788984 - Posts: 31
I am trying to implement a simple crossover study using Sierra’s Trading System – Study subgraph crossover indicator/study. My issue is seeing (not seeing) the crossover points on the chart. I am using a moving average for one line and Donchian Channel (upper) for other line. All looks well on the chart, but I can’t seem to generate any of the markers to show the “crossing from below/ crossing from above” on the charts. Furthermore, without the markers, the backtest is not producing any trades.
[2023-06-19 17:13:39]
Sawtooth - Posts: 4120
'Enabled' must be set to Yes.
'Send Trade Orders To Trade Service' must be No for Sim and backtesting, and Yes for live.
Date Time Of Last Edit: 2023-06-19 17:14:08
[2023-06-19 20:17:09]
Yes, I’ve done both. Just can’t seem to see the markers for the crossovers and also no trades generated.
[2023-06-19 23:27:04]
The Buy and Sell indicators on this subgraph are +1 and -1respectively. Does my chart need to be scaled to +1 and -1 to show the indicators? Even so, I am not registering any trades on backtests.
[2023-06-20 02:28:10]
The Trading System - Study Subgraph Crossover study outputs 1 when true and 0 when false.
However, for me, this study marks the crossovers incorrectly.
Try this instead:
Add two instances of the Trading System Based On Alert Condition study, one for longs and one for shorts.
Use formulas like these on the Alerts tab:
Longs:
=CROSSFROMBELOW(ID1.SG1,ID2.SG1)
Shorts:
=CROSSFROMABOVE(ID1.SG1,ID2.SG1)
where ID1.SG1 is the MA, and ID2.SG1 is the upper Donchian channel.
[2023-06-21 01:45:10]
Thank you TomGilb for your input and guidance. I am still unable to see any indicator reflecting that conditions were met. Even with a simple "crossfrombelow" using closing price (C) against upper Doncian Channel with the ES futures contract. The ES futures prices are in the 4100 range. When conditions are met, I assume that means (+1). How do I see the the star,triangle,square, etc. indicator on my chart?
[2023-06-21 02:35:42]
1. Add the Trading System Based On Alert Condition study
-Set 'Enabled' to Yes
-Set 'Order Action On Alert' to Buy Entry
-Put this formula on the Alerts tab:
2. Duplicate the above study
-Set 'Order Action On Alert' to Sell Entry
The above formulas assume:
ID1.SG1 is the MA
ID2.SG1 is the upper Donchian Channel
Edit the formulas as needed.
Date Time Of Last Edit: 2023-06-22 18:30:17
[2023-06-22 18:22:21]
I guess it would help if I typed correct spelling of CROSSFROMABOVE. Thank you so much for your assistance. Embarrassed at the simple correction that took me days to realize.
