Date/Time: Wed, 27 Nov 2024 23:39:09 +0000
Market Depth Windown Open command in the Control Bar
View Count: 228
[2023-06-19 11:03:38] |
Federico Roveda - Posts: 34 |
Hi there, is there a way to add the command 'Chart>Open Market Depth Window' in the Control Bar? Thanks in advance |
[2023-06-20 13:24:09] |
Sierra_Chart Engineering - Posts: 17198 |
Yes but use the Open Market Depth Window command that is under the File menu: Control Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
