Date/Time: Wed, 27 Nov 2024 23:33:49 +0000
Nasdaq Total View MSTR
View Count: 340
[2023-06-19 08:39:25] |
Selfmadejared - Posts: 7 |
Hi there! I have been commissioned by a client to create a set of charts for MSTR. I am using SC Data to get access to the charts so I can add the studies he wants. Everything is all fine until I get to the higher timeframe. When I look at a Quarterly & Yearly Market Profile chart, a significant amount of data is cut out. I tried putting the chart to Historical, but it gives me an error message. I was wondering what the problem may be? Thanks!
[2023-06-19 08:40:11] |
Sierra_Chart Engineering - Posts: 17198 |
We would not recommend using the NASDAQ TotalView data. Only use the consolidated tape data. In this case the symbol will be: MSTR Additionally follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-20 23:11:25] |
I tried loading MSTR on the consolidated tape data & I got this error message. Any ideas?
Screenshot 2023-06-20 190943.png / V - Attached On 2023-06-20 23:10:51 UTC - Size: 123.94 KB - 78 views Attachment Deleted. |
[2023-06-21 15:01:35] |
You must update Sierra Chart to the current version. Instructions: Software Download: Fast Update There is no other possibility. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-21 15:02:19
