Date/Time: Wed, 27 Nov 2024 00:22:23 +0000
QuoteBoard Fields with imported EOD data
View Count: 1385
[2014-07-02 09:39:39]
Trint - Posts: 115
Hello SC Support,
I currently import a huge amount of stock/instrument End-of-Day data (EOD) from a data source into Sierra Chart using a script. I can then view all these individual stocks in the Quoteboard and reference them in the Chartbook with the link feature.
Question is, is it possible to use more than just the Symbol Field for the chart linking reference to display the stock (i.e is it possible to list Open, High, Low, Close price data for those manually imported EOD stocks). I'm particularly interested in the 'Alerts' field highlighting any alert price triggers since the last EOD update rather than having to go through each one.
I did notice that the charts only update when I actually click on the Symbol in the Quoteboard, it doesn't update dynamically.
Thanks in advance.
Date Time Of Last Edit: 2014-07-02 09:41:55
[2014-07-02 16:32:29]
No. The quote board is designed to work only with a real-time data feed providing current quote data. You could develop a real-time data feed server using DTC:
https://www.sierrachart.com/index.php?page=doc/doc_DTCProtocol.php
Not really sure what you mean by this. If you are working with a text data file, we would not expect that you would be doing dynamic updating to the files. Really we are not clear what you are doing and what you are expecting.
Date Time Of Last Edit: 2014-07-02 16:32:48
[2014-07-02 18:31:39]
Trint - Posts: 115
Ah not to worry.
I basically download one ADVFN file with all the specific stock lisiting data for the day. The script reads that file and individually opens those stock files (.Dly) one-by-one, prints to the end of that stock file, closes it and moves onto the next for all those Stock.Dly files that exist in the directory.
I was hoping that on opening the Chartbook with the Quoteboard (after the script update), any price action since the last update passing an alert would be highlighted in the QB.
