Date/Time: Wed, 27 Nov 2024 23:45:10 +0000
[Programming Help] - trying get draw style :point depend display location
View Count: 301
[2023-06-18 13:10:04]
User278398 - Posts: 291
hello,
im trying get "point"(or other shape) which it depend by "display location" ("study subgraph above/below bar as text" study).
i get changing for "display location" as i want only if i choose in the "draw style" "custom value at y"
how can i make shape which depend by "display location"?
regards
[2023-06-18 13:14:20]
i mange to manipulate by taking "custom value at y with border" and made it very small and it looks like a shape i can work with...
but it still not look very good.
other option will be good as well
reards
[2023-06-18 14:26:11]
User907968 - Posts: 823
You can't using that study, due to how the text position is set inside the study.
Instead you would need to use somthing else, like color bar based on alert condition, which does allow you to define the display position of shape type drawstyles.
Color Bar Based on Alert Condition
