Date/Time: Wed, 27 Nov 2024 23:30:50 +0000
ChartBook
View Count: 251
[2023-06-17 21:11:25] |
User474861 - Posts: 2 |
I am getting error message saying to contact sierra to convert my files. Please can I have updated version?Error: No file was uploaded.
Attachment Deleted. G7FXFOUNDATIONDOMCHARTBOOK-200330-085855.Cht - Attached On 2023-06-17 21:09:55 UTC - Size: 276.18 KB - 121 views |
[2023-06-20 17:03:53] |
Sierra_Chart Engineering - Posts: 17198 |
You really need to contact the provider of that Chartbook and have them give you an updated Chartbook. You can convert it following these instructions: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
