Date/Time: Wed, 27 Nov 2024 23:25:56 +0000
[User Discussion] - historical data problem
View Count: 234
[2023-06-17 12:32:32]
User259724 - Posts: 43
Hello:
I am trying to use delayed historical data in another instance of Sierra chart. I am unable to navigate to "SC Data - All Services". I have attached screenshots of the data/trade service settings as well as Sierra chart server settings. I am not sure what setting is not correct.
Thanks for any help received.
https://www.sierrachart.com/image.php?Image=1687004728240.png
https://www.sierrachart.com/image.php?Image=168700476772.png
https://www.sierrachart.com/image.php?Image=1687004832203.png
https://www.sierrachart.com/image.php?Image=1687004850706.png
[2023-06-20 17:09:10]
Sierra_Chart Engineering - Posts: 17198
If you started that instance with File >> New Instance you cannot do what you want. You need a separate installation of Sierra Chart:
Using Multiple Data and Trading Services at the Same Time
And follow the instructions here for that installation:
Delayed Exchange Data Feed
