Date/Time: Thu, 28 Nov 2024 00:33:28 +0000
Alerts not working
View Count: 257
[2023-06-16 16:40:30]
acc283158 - Posts: 1
See below for attached message.
attachmentMsg.txt - Attached On 2023-06-16 16:40:26 UTC - Size: 594 B - 115 views
[2023-06-16 16:53:47]
John - SC Support - Posts: 36350
We would need to know the specific studies that are ID1 and ID6.
If these are TPO profiles, then SG21 and SG25, are only to set colors. They do not hold the information for the Initial Balance Range or the Opening Range. This specific information can not be gotten from the TPO profile study itself.
To get the Initial Balance, use the "Initial Balance" study. Refer to the following:
Initial Balance
To get the Opening Range, you would have to create a chart that has a bar period equal to the opening range time that you want, and then get the range of the opening bar from that chart.
