Date/Time: Thu, 28 Nov 2024 00:33:00 +0000
Historical data for NQ
View Count: 279
[2023-06-16 13:29:40] |
maxm1987 - Posts: 116 |
Hi Sierra, I asked this question before but didnt know what to do with the answer. Maybe John can answer. My simple question is why i cant go back further in the attached chart to show data earlier than 2022. When i try to change the dates the dates will always default. I need historical data so please tell me how to move back further. Date Time Of Last Edit: 2023-06-16 13:30:13
Chartbook16.Cht - Attached On 2023-06-16 13:30:09 UTC - Size: 12.24 KB - 312 views |
[2023-06-16 19:20:20] |
Refer to the information at the following link: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Instructions to Download/View More Historical Intraday Data If you are wanting to see a specific contract from a specific date (such as the M contract from 2022) then you would need to enter the symbol for that specific contract (such as ESM22-CME - the exact symbol and format will depend on your service settings). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
