Date/Time: Wed, 30 Sep 2026 08:00:50 +0000
SC on windows ARM/VM on apple max studio
View Count: 2978
[2023-06-16 12:59:29]
User525733 - Posts: 126
the issue below is stopping me from using SC:
I am moving to a new compute environment : windows ARM on VM running on apple Mac studio.
when i moved my custom ACSIL studies that were compiled on a win64 machine ( retiring soon) to the new environment (windows on VM/Apple)...i got the errors below: (relevant sections of the log)
Found DLL: User-contributedStudies_64.dll 12023-06-15
UserContributedStudies_64.dII loading error. Windows error code 193: %I is not a valid Win32 application. | 2023 06 15
and
Triggering next historical data download in queue. 2023 06-15 WI 5: 13533
No download requests in the queue to start downloads for. | 2023 06 15
Socket (3) Socket gracefully closed by remote side. | 2023 06 15 W 15:13.678
Socket Closed. 06 15
Found DLL: 2023 06 15 WI 5:31.726
Found DLL: UserContributedStudies_64.dII 2023 06 15 WI 5:31.726
loading error. Windows error code 193: %I is not a valid Win32 application. 12023 06-15 WI 5:31753
InternalVersionNumberToFiIeNameMap is empty for 2023 06-15 WI 5:31753
Closest match search for: returned empty result. 2023 06-15 WI 5:31753
UserContributedStudies_64.dII loading error. Windows error code 193: %I is not a valid Win32 application. 2023 06-15 WI 5:31779
InternalVersionNumberToFiIeNameMap is empty for UserContributedStudies 2023 06 15 WI 5:31.77g
Closest match search for: returned empty result. 2023 06-15 5:31779
Found DLL: UserContributedStudies_64.dII 2023-06 15
nogi_custom_studies.dll loading error. Windows error code 193: %I is
InternalVersionNumberToFiIeNameMap IS empty for 2023 06 15
Closest match search for: returned empty result. 2023 06-15 WI 7:08.996
InternalVersionNumberToFiIeNameMap is empty for UserContributedStudies 2023 06 15 WI 7:08.998
seems there is an issue with the SC dll that loads custom dlls. please advise
thx
[2023-06-20 13:28:01]
Sierra_Chart Engineering - Posts: 25008
Custom studies that you want to use with the ARM64 version of Sierra Chart have to be built for ARM 64.
This would require using Visual C++ to build them.
Date Time Of Last Edit: 2023-06-20 13:28:06
[2023-08-29 20:53:48]
fabse - Posts: 10
I built my custom strategy for arm64 see this post please Sierra Chart Executables for ARM 64 Processor but I get an error when the strategy is loaded. See the link.
[2023-08-29 21:22:59]
John - SC Support - Posts: 48062
The particular error you are getting states that it is not a Win 32 application. Is the VM you are running a 32 bit VM?
Sierra Chart is only built for 64 bit architectures.
[2023-08-29 22:26:28]
fabse - Posts: 10
The problem I was referring to in the other thread is the following:
I have build my own custom studies with arm64 by changing the VisualCCompile.bat script and run it on my own like this inside a win ARM VM on parallels on a mac. So it is all ARM arch:
call "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build\vcvarsall.bat" arm64
cl /JMC /MP /analyze- /Zc:wchar_t /Z7 /Od /GS /W3 /RTC1 /Zc:inline /D "_WINDOWS" /D "_USRDLL" /D "_WINDLL"
/Gd /Gy /GR- /GF /fp:precise /MTd /std:c++17 /LD /EHa /WX- /diagnostics:classic /nologo "C:\SierraChartARM\ACS_Source\FabsesStudies.cpp"
/link "Gdi32.lib" "User32.lib" /DLL /DYNAMICBASE /DEBUG /INCREMENTAL:NO /OPT:REF /MACHINE:ARM64 /OUT:"C:\SierraChartARM\Data\FabsesStudies_ARM64.dll"
it seems to build everything correctly for arm but when I load the custom strategy arm64 dll I get this weird error:
"The custom study xxxx required version 2499 or higher of sierra chart. Current version 2499."
Any ideas on how to fix this?
[2023-08-30 09:38:05]
Does not make any sense to us. But make sure you are using an up-to-date SierraChart.h header file which is located in the /ACS_Source folder.
Date Time Of Last Edit: 2023-10-14 20:21:14
[2023-10-14 16:17:17]
fabse - Posts: 10
I found the issue.
I downloaded the latest version today.
If I open the 64 bit version (SierraChart_64.exe) it says, version: 2555
If I open the ARM version (SierraChart_ARM.exe) it says, version: 2543
In the sierrachart.h file this is defined:
// SC_DLL_VERSION gets updated only when there have been changes to the DLL
// study interface. This should be set to the Sierra Chart version number
// that includes the changes made to the interface.
#define SC_DLL_VERSION 2551
If I change this to:
#define SC_DLL_VERSION 2543
and compile with the bat file mentioned above I can load my custom studies in the ARM version.
So I think the fix from your side might be to also release the ARM version as version 2555?
[2023-10-14 20:22:25]
We have put out a new ARM version.
[2023-11-19 13:59:42]
autobahn - Posts: 27
Similar issue with version 2564 - but 2562 works. Is there an easy way to tell which versions have matching headers before downloading?
Date Time Of Last Edit: 2023-11-19 16:46:57
[2023-11-19 20:16:41]
We will generate a new ARM version now.
[2025-03-07 15:36:18]
User433762 - Posts: 1
I am running into similar (I believe) issues like others in this post. I am running SC on an Apple M2 through Parallel. I made a custom study in MS VS 2022 and was built successfully in VS through release/ ARM 64. When trying to add the custom study in SC (through Analysis/ Studies/ add custom study), an error message appeared stating that the custom study requires version 2624 or higher, current version 2624). I also read SierraChartStudies_ARM.dll v2596 in the Add Study screen which I do not understand, should be 2624 too?
Is anyone familiar with this the error message and has found a "workaround" to solve this issue so that the custom study built in VS works properly?
Date Time Of Last Edit: 2025-03-08 17:10:31
imageError message SC.png / V - Attached On 2025-03-07 15:29:46 UTC - Size: 16.29 KB - 192 views
