Date/Time: Thu, 28 Nov 2024 00:24:00 +0000
Multiple Accounts Same Broker
View Count: 279
[2023-06-16 07:54:40]
eaglefutures - Posts: 48
Hi support,
Hope all good on your side. I have a separate installation of sierrachart in its own separate folder.
I login with my existing user id.
I am in Trade > Trade Account Monitor.
I want to add an account and delete an account so that there is only a single account per installation.
How do I add either a sub-account or a main account, to a separate installation from the same broker.
I want that only that account is visible in that installation and no other broker accounts. ( From the same Broker ), Same sierrachart account login , same computer .
I have read the instructions here Using Multiple Data and Trading Services at the Same Time
Trade Account and Risk Management: Managing SubAccounts
I am a bit confused as to how to implement this, your assistance is appreciated.
thanks
[2023-06-16 08:19:03]
Sierra_Chart Engineering - Posts: 17199
This is not supported at all:
The documentation you referenced, is not related to what you want to do.:
[2023-06-16 08:48:15]
Thank you for such a quick response. How do I show only one account per installation , or folder in sierracharts ? from the same broker, either a main account or a sub-account ?
[2023-06-16 09:51:30]
You cannot. This is not within your control. Other than to contact the broker and let them know how many accounts to set on the username you are logging into.
Date Time Of Last Edit: 2023-06-16 09:51:40
