Date/Time: Tue, 26 Nov 2024 22:35:28 +0000
Can not switch UES
View Count: 1064
[2014-07-01 14:56:01] |
User53601 - Posts: 105 |
Hello, Could you please help with this: I can not swith the UES, Use evening session button, on the toolbar, as shown on the picture. Probably I switched something unwillingly. Jaro |
[2014-07-01 15:22:42] |
Are you able to check and uncheck Chart >> Use Evening Full Session on the menu?
[2014-07-01 15:40:25] |
Yes, I am able to switch off/on via Chart >> Use Evening Full Session on the menu
[2014-07-01 16:41:34] |
Do you still notice this problem with the ToolBar button being disabled after restarting Sierra Chart?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-01 16:42:21
[2014-07-01 16:48:27] |
I have restarted the Sierra, and now it works ok. So simple. Thank you Jaro |
