Date/Time: Thu, 28 Nov 2024 00:41:28 +0000
Color bar based on alert condition help please!
View Count: 261
[2023-06-15 16:09:35] |
matt_k93 - Posts: 2 |
Hi, I need some help with the color bar based on alert condition study please. I would like to be able to use the 'Ask volume Bid volume difference percent' from the numbers bars calculated values study as the reference and have the bars colored when this value is either 20% or higher or -20% or lower. I have played around with different formulas in the alert section but i can't seem to get it right. Could you please explain how i can do this or what the correct formula to use would be? Many thanks. Date Time Of Last Edit: 2023-06-15 16:12:53
[2023-06-15 17:16:55] |
You would need to use the "Volume at Price Threshold Alert V2" to do this. Refer to the following: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
