Date/Time: Wed, 27 Nov 2024 23:26:38 +0000
[User Discussion] - how to use multiple chartbooks
View Count: 278
[2023-06-15 16:04:43]
User259724 - Posts: 43
Hello:
I want to tab through multiple chartbooks in order to view end of data on equities. One chartbook would have 3 charts; monthly, weekly and daily. Only indicators on charts would be 6 moving averages and volume; so not much draw on CPU. I wish to view and tab through quickly about 400 stocks. Would I have to have 400 chartbooks, and is there a limit on the number of chartbooks? I would tab through these chartbooks very quickly using a hot key. I would use a new instance of Sierra charts in order not to interfere with my day trading charts. I would set all chartbooks to open with the new instance. Can this be done? Is this the best way to do this? Is there a better way?
Thanks for any responses.
[2023-06-16 00:17:39]
ForgivingComputers.com - Posts: 960
Yes, there is a better way. If the 400 chartbooks are all copies of each other and differ only by the symbol, then you can use a Quote Board and one Chartbook.
File>>New Quote Board
This allows you to click on any symbol and have the chart load it.
You can import your list of equities from a text file.
[2023-06-20 22:05:08]
Thank you this worked perfectly!
