Date/Time: Thu, 28 Nov 2024 00:44:24 +0000
Study
View Count: 215
[2023-06-15 15:30:57]
User379557 - Posts: 37
Is there a study or indicator which shows the current close and current open (Both close and open) are higher or lower than the previous period? Its A simple calculation, however I cant find a study or indicator that performs this simple calculation. Thank you-
[2023-06-15 17:00:52]
John - SC Support - Posts: 36350
Use two copies of the "Daily OHLC" study. Set the Input one of them for "Reference Days Back" to "1". Then you will see the Open/Close for the previous day and the Open/Close for the current day at the same time. Refer to the following:
Daily OHLC
