Date/Time: Thu, 28 Nov 2024 00:40:46 +0000
Sierra Chart takes over 10 minutes to land the data feed
View Count: 227
[2023-06-15 06:10:39] |
User543432 - Posts: 2 |
Hallo Sierra Chart takes over 10 minutes to land the data feed. This is exceptionally long although nothing has been changed in the settings. What can be done about it? |
[2023-06-15 10:08:59] |
Sierra_Chart Engineering - Posts: 17199 |
What do you mean by "land the data feed"? Also refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
