Date/Time: Fri, 22 Nov 2024 08:36:12 +0000
Hot key or "tool icon" to rapidly enable a chart to switch from
View Count: 1948
[2013-05-02 17:03:50]
steve i depner - Posts: 14
Is there a hot key or a resident tool baricon to allow me to rapidly switch between candles and OLC bars in a chart. Similar to being able to change time frames or symbols like we are able to do now?
[2013-05-02 20:00:52]
maxpi - Posts: 181
Global Settings - Customize Toolbar you can find settings that do exactly what you want with a single click.
[2013-05-02 23:07:09]
Done deal, Many thx. Does SC have a preferred way to show as solved or close this support request?
[2013-05-03 04:47:42]
For reference:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSettingsMenu.html#CustomizeToolbar
Date Time Of Last Edit: 2013-05-03 04:47:50
