Date/Time: Thu, 28 Nov 2024 00:33:48 +0000
1min candlestick bar volume issues
View Count: 345
[2023-06-14 23:09:06]
User223734 - Posts: 103
Dear Sir,
I am using MNQU23-CME symbol for my chart, I note the real time volume is different when compared to aftermarket.
eg. Time Zone setting Chicago (-6 CST/-5 CDT)
Real time : 1 min candlestick volume on Wed 6/14 at 10:14 is 2827
Aftermarket : 1 min candlestick volume on Wed 6/14 at 10:14 is 526
Please helps to check the issue.
[2023-06-15 13:44:45]
John - SC Support - Posts: 36350
Most likely your chart rolled over to the new contract, so you are now seeing the data for the U contract, whereas during the day yesterday - you were viewing the M contract.
[2023-06-15 16:00:08]
I have manually rolled over the new contract on Tuesday! I am only viewing the U contract only.
[2023-06-15 17:12:01]
You are definitely having an issue with the particular contract you are viewing. The volume for the bar on 2023-06-14 at 10:14 is the following:
MNQM23-CME: 526
MNQU23-CME: 2827
[2023-06-16 00:51:55]
Dear John,
As I mentioned, I changed the chart symbol to NMQU23-CME on Tuesday before 08:30am, I just check (@ 7:31pm Chicago time zone) the 1min candlestick volume on 8/15 from 08:30am to 04:00pm, it is back to normal but 8/14 and 8/13 candlestick volume record still has issues.
I noted I am using "Continuous Futures Contract- Date Rule Rollover, Back Adjusted" setting, I wonder if it will affect the initial rollover candlestick volume record?
Remark : I am using IB 'U23 contract" 1min candlestick bar volume for the comparision.
[2023-06-16 01:06:48]
Dear John,
I think I got the answer, when I change "Continuous Futures Contract- Date Rule Rollover, Back Adjusted" to "Continuous Futures Contract- Volume Based Rollover, Back Adjusted", all back to normal!
