Date/Time: Thu, 28 Nov 2024 00:41:49 +0000
MNQU23-CME
View Count: 386
[2023-06-14 22:50:02] |
User223734 - Posts: 103 |
Dear Sir, As per my chart for MNQU23-CME on today and yesterday, I noted the volume of 1 min candlestick bar is not same as real time (Oty is small than real time), please check. |
[2023-06-15 13:41:58] |
We need more information. Exactly what bar, what is the opening time of the bar and what are you comparing to. Please give us an image of what you are seeing.
[2023-06-16 11:09:25] |
Sierra_Chart Engineering - Posts: 17199 |
If this is a Continuous Futures Contract chart, refer to: Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-16 11:09:35
