Date/Time: Thu, 28 Nov 2024 00:46:10 +0000
y axis
View Count: 243
[2023-06-14 15:35:28]
User841161 - Posts: 221
Is there a way to have y axis on chart to go from high numbers to low, instead of low number to high. Such as sample chart- right one is high numbers to bottom to low numbers on top.
imageEuro Y Axis 2023-06-14 10-27-58.png / V - Attached On 2023-06-14 15:34:33 UTC - Size: 125.27 KB - 67 views
[2023-06-14 15:51:33]
John - SC Support - Posts: 36350
You can not invert the axis, but you can invert the prices, or multiply them by -1, which will give you the same effect (just different ways of viewing the prices). Refer to the following:
Chart Settings: Invert Prices (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Multiply Bars By -1
