Date/Time: Wed, 27 Nov 2024 22:49:44 +0000
2 Question about possibilities Custom study for the platform
View Count: 342
[2023-06-14 14:21:45] |
GravisHTG - Posts: 306 |
First question. Is it possible to build a study that will take External data and plot it in a dedicated subgraph ? ( all plot method will be include in the external file ) Second Question Is it possible to Work with Data before its process into agregations of different TF ? so in pure tick data , but without loading the Actual 1 tick chart ? Thanks in advance for your help. |
[2023-06-22 10:26:04] |
Sierra_Chart Engineering - Posts: 17198 |
Yes: Is it possible to Work with Data before its process into agregations of different TF ? so in pure tick data , but without loading the Actual 1 tick chart ?
This is done by creating your own custom chart bars: ACSIL Interface - Custom Chart Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-22 14:36:46] |
How can we add metrics to the Number Bar Calculated values study ?
[2023-06-23 10:06:16] |
We do not understand the question.
[2023-06-23 20:02:56] |
So we have the Number Bar calculated value study - and it give a lot of different metric , I wonder if , via Some rules I build , I can add Metric to that study.
[2023-06-26 15:08:42] |
You can create your own Numeric Information table. This is what we recommend: ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
