Date/Time: Thu, 28 Nov 2024 00:49:44 +0000
Order shut off
View Count: 210
[2023-06-14 13:47:37] |
OriolCasas - Posts: 163 |
Hello, I entered an order long on CL today, somehow it shut off brefore my stop, I see it say on the stop (limit) and I think that can be the reason. See picture attached. Can you help me out? Thank you |
orders shutting off.png / V - Attached On 2023-06-14 13:47:31 UTC - Size: 78.43 KB - 55 views |
[2023-06-14 14:49:38] |
It is possible that since it is a Stop Limit order that it did not fill. Also note that for a Stop Limit there is an offset applied, so the price needed to be below 70.17 in order to fill the limit. Refer to the information here: Order Types: Stop-Limit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
