Date/Time: Thu, 28 Nov 2024 00:43:24 +0000
Double price bars after rollover.
View Count: 218
[2023-06-14 13:22:58] |
Spartan79 - Posts: 54 |
After I rolled over to September contract I get double daily price bars from 5-30-2023 on. It only happens on 2 charts with RTH session, all the other charts seem to be ok. Circled 1 and 2 are the same bars with same date, just different price because of the rollover. I deleted all data and downloaded, and it didn't help. Thank you. |
Double bars.jpg / V - Attached On 2023-06-14 13:18:45 UTC - Size: 276.52 KB - 67 views |
[2023-06-14 13:41:36] |
Sierra_Chart Engineering - Posts: 17199 |
This is actually an Intraday chart. Follow the instructions here to re-download the data for the last two contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
