Date/Time: Thu, 28 Nov 2024 01:44:18 +0000
Graphic has an issue wit data plotting after rollover.
View Count: 336
[2023-06-13 19:51:33] |
User864567 - Posts: 4 |
Hello I just installed Sierra in a new computer and proceeded with the rollover for the September contracts and after completing the initial setup their is a big gap between the final data plotting for the trading day corresponding to 06/12/2023 (this past Monday) and 06/13/2023 is there a way to fix this gab because it doesn't seems like a natural gap from the market movement. Please see attached image for reference. If by any reason the screenshot is not attached please use this link to an online access to the screen shot http://icecream.me/ceea576400879d158564f474daab6928
Sierra support screen shot.jpg / V - Attached On 2023-06-13 19:46:36 UTC - Size: 258.77 KB - 74 views |
[2023-06-13 20:10:10] |
This is the normal difference between contracts. In order to not show that gap, you would need to use a Back-Adjusted Continuous Contract. Refer to the following: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
