Date/Time: Thu, 28 Nov 2024 01:48:58 +0000
Need Help with Autotrading
View Count: 251
[2023-06-13 19:11:56]
User198717 - Posts: 15
I have looked as much as I could find on auto trading with the spreadsheet. Can anyone look at this screenshots and let me know if you see something missing to have the chart auto trade?
imageSpreadsheet1.png / V - Attached On 2023-06-13 19:10:19 UTC - Size: 238.91 KB - 68 views
imageSpreadsheet2.png / V - Attached On 2023-06-13 19:10:27 UTC - Size: 258.11 KB - 70 views
imageSpreadsheet3.png / V - Attached On 2023-06-13 19:10:33 UTC - Size: 241.93 KB - 71 views
[2023-06-13 19:47:27]
John - SC Support - Posts: 36350
You do not have anything in Columns K, L, M, or N. K and M in particular are for Buy/Sell Entry. You need to put your conditions into those cells such that you get a True (non-zero result) when you want the trade to occur, otherwise the value should be 0.
[2023-06-13 19:57:04]
Do you know of anything I could reference?
[2023-06-13 20:10:50]
Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading: Creating a System or Alert
