Date/Time: Thu, 28 Nov 2024 01:39:26 +0000
Volume by Price color problem
View Count: 253
[2023-06-12 19:07:12] |
User213504 - Posts: 69 |
The VBP colors are not being applied as indicated in the settings window. Pic attached. Ron |
[2023-06-12 21:52:43] |
We can not say for sure, as we are not positive of what colors you are referencing, but the main issue is simply that the Volume by Price profile is too compressed. The easiest resolution is to increase the "Ticks per Volume Bar". Refer to the following: Volume By Price Study: Ticks Per Volume Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-13 13:57:17] |
Thanks, I expanded the study to get a better view and saw that it was displaying up and down trades. I clicked no on the settings and that cleared everything up. Thanks again, Ron |
