Date/Time: Thu, 28 Nov 2024 01:37:28 +0000
The Chartbook file is not compatible. Contact Sierra Chart support for help with convertin
View Count: 259
[2023-06-12 18:36:36] |
User198717 - Posts: 15 |
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\Data\VWAP-22Levels.Cht | 2023-06-12 18:34:57.738 * Can anyone help with this? |
VWAP-22Levels.Cht - Attached On 2023-06-12 18:36:03 UTC - Size: 3.53 MB - 66 views |
[2023-06-12 21:43:45] |
Follow these instructions: Chartbooks (Workspaces): Opening Older Chartbooks For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
