Date/Time: Thu, 28 Nov 2024 01:41:18 +0000
Question on Replay
View Count: 242
[2023-06-12 16:01:21] |
User733657 - Posts: 1 |
"Why can't I use Replay? It doesn't respond when I click on it. What could be the reason?" It is not supported to replay historical chart why? |
[2023-06-12 17:09:45] |
Is the chart you are trying to replay an Intraday or an Historical Daily Chart? If it is Intraday - then how are you starting the Replay? If you are not using the option for "Use Start Date-Time", then you need to scroll your chart back to where you want to start the replay from. Refer to the following: Replaying Charts: Basic Chart Replay Instructions You can not replay Daily charts because each bar is just the High/Low/Open/Close information, so there is not really anything there to replay. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-12 17:12:26
