Date/Time: Mon, 25 Nov 2024 14:46:18 +0000
How to fast download data for US stocks?
View Count: 442
[2023-06-12 14:36:30] |
User361939 - Posts: 165 |
I created watchlist for us stocks by "Symbol->ADD NYSE" Now i have watchlist containg all NYse symbols. I do understand that first time download could take a while. But for the next download i believe that it took only couple minutes. My internet speed is 1GB/s. Weight of one file is around 600KB. So even for 3K symbols it should be pretty fast. Yet, when i downloaded next day data, it took 1hour to download all files. how can i make it download "fast"? |
[2023-06-12 16:29:12] |
John - SC Support - Posts: 36244 |
You really need to use the "Intraday File Update List" to be continuously getting the data. Refer to the following: Global Settings Menu: Intraday File Update List (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-12 17:28:02] |
Sierra_Chart Engineering - Posts: 17174 |
Also refer to: Changing Chart Bars Period: Improving Performance of Loading Chart Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-13 15:35:50] |
BUT i am using only EOD charts (DAILY/Weekly_) I don't need intraday charts. Is it possible to make it work with EOD? |
[2023-06-13 16:50:56] |
There is not an option to pre-download daily data.
[2023-06-13 17:42:46] |
Can you consider adding such option for Stock Traders? I am not sure why is this a problem since those files are very light, so whole "package" of NYSE / NASDAQ DLY file will have 200MB on top. You as sierra can give direct link for EOD data that will be downoladed directly into DATA folder. |
[2023-06-14 16:09:42] |
Can option "Download data from end of chart" works for EOD Data? That could solve time issues of downloading data
[2024-02-12 16:02:26] |
User624595 - Posts: 207 |
Can you add auto download historical data?
[2024-02-14 05:37:53] |
Related to this, refer to: Changing the Symbol of a Chart: Using the Associated Watch List You can fill this list automatically with an entire exchange. And refer to: Changing the Symbol of a Chart: Downloading Historical Daily Data for Symbols List Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-02-26 00:43:34] |
Is it possible to add an option to do this step automatically? "Select Edit >> Download Daily Data for Associated Watch List Symbols."
[2024-02-26 02:04:04] |
No it will need to be done manually.
