Date/Time: Thu, 28 Nov 2024 00:37:11 +0000
Watchlist based on my own data files
View Count: 314
[2023-06-12 14:24:58] |
User361939 - Posts: 165 |
Hello, I Have my own data files for stocks (those are txt files). I install second sierra (using non service , data service) I create watchlist following your guide. My e.g: TXT file ABC.txt Structure of file: Symbol,Date,Open,High,Low,Close,Volume ABC,20150527,19.2000,20.0000,18.4000,19.3500,62411 ABC,20150528,19.6600,19.8000,18.7500,19.8000,1895 ABC,20150529,19.7900,21.0000,18.4500,20.0000,4663 ABC,20150601,20.8900,20.8900,20.4000,20.8000,2698 I create symbol in watchlist "AB"C. Unfortunatelly, none of charts are opening after clicking on symbol. After clicking i see that is created dly file with symbol name. So i have ABC.dly file (on chart its info - symbol settings not found for current service) How can i create watchlist based on my own txt data files? Regards Date Time Of Last Edit: 2023-06-12 14:25:26
sierra_problem.png / V - Attached On 2023-06-12 14:24:11 UTC - Size: 2.22 KB - 67 views |
[2023-06-12 16:26:32] |
When you are wanting to use your own data, your Sierra Chart instance needs to be completely disconnected from any trading service (i.e. select "File >> Disconnect"). Not just set to "No Service". Refer to the information here: Exporting and Importing Intraday Data Files: Import and Load For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-13 15:32:14] |
My TXT files containing EOD data At the atachment, screens of exammple of my files in folder DATA and also how my watchlist looks like. I did set "NO SERVICE" also disconected from services, but when i click on chart symbol from wathclist, platform automatically conecting. So what should i do? |
files_for_list.png / V - Attached On 2023-06-13 15:28:41 UTC - Size: 2.35 KB - 72 views in_watchlist.png / V - Attached On 2023-06-13 15:31:01 UTC - Size: 5.85 KB - 73 views |
[2023-06-13 22:57:46] |
Sierra_Chart Engineering - Posts: 17199 |
Change the file extension to .dly for those files.
