Date/Time: Thu, 28 Nov 2024 01:29:44 +0000
Super trend study calculation problem.
View Count: 281
[2023-06-12 11:01:47] |
User538264 - Posts: 26 |
Hi, I am trying to use the Super trend study. But there is some problem with the calculations as it is becoming flat after certain candles on chart. Please refer to the image for context. This is only happening on currency charts so there maybe a problem with decimals. I am attaching the settings I am using for the study as well. How do I get over this? Thanks in advance. https://www.sierrachart.com/image.php?Image=1686567584152.png |
Attachment Deleted. |
[2023-06-12 16:02:22] |
Attached is what we get for 6E using the same Inputs as you specified. As you will see, we can not reproduce what you are seeing. Please get us another image of your chart by using "Edit >> Screen Images >> Save Chart to File" and then attaching that image to this post. This ensures that we can see the bar times and other information in the chart to help us determine what may be occurring. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
6EM23-CME[M] 1 Min #5 2023-06-12 10_59_08.840.png / V - Attached On 2023-06-12 16:01:29 UTC - Size: 79.51 KB - 62 views |
