Date/Time: Thu, 28 Nov 2024 01:32:52 +0000
Symbol Rollover Message
View Count: 301
[2023-06-12 00:54:27]
User940772 - Posts: 74
The "Symbol need to Rollover. Click to Rollover" message doesn't disappear on my second instance Sierra charts. Is there a way to turn this off? I can't find anything on it in the help files.
[2023-06-12 14:54:32]
John - SC Support - Posts: 36350
Has that chart been rolled over to the new contract?
[2023-06-12 15:30:24]
At the time, no. I did roll over this morning so the issue is moot for the time being but it's a problem I have been dealing with for a while now. It's not a huge issue because I usually roll over soon anyway. It's just really annoying though to deal with at the time. This only occurs on instances of Sierra I created that I keep on my D: drive and not the new instance launched from the primary. If it's something complicated that the engineers would have to look into I'll just live with it. I just thought it might be a simple on/off switch that I might have missed.
[2023-06-12 17:05:29]
In general, the window should go away after awhile.
A couple of items to think about.
- We are not sure of the symbol you are using, but in general the rollover for many CME Futures is for 1 day before the 3rd Friday in the contract month, which would be this upcoming Thursday - June 15th. Therefore, we have to assume that you are getting the message you are related to the Volume, which would imply that you have the following option enabled:
General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol)
If you set the above option to "No" then you will not get the message until the actual rollover day.
- You can completely remove the display of all warning/informational messages, although we do not recommend this. Refer to the following:
General Settings Window: Show On-Chart Status Messages (Global Settings >> General Settings >> Charts >> Charts)
[2023-06-12 17:22:02]
Well John, I have to say you are very good at what you do. I am indeed using volume based rollover. I appreciate the tips on the settings and will take a better look at how I have things set up after RTH. Thanks again.
