Date/Time: Thu, 28 Nov 2024 01:36:54 +0000
Why market profile prices change after roll over?
View Count: 259
[2023-06-12 00:14:22] |
User910963 - Posts: 80 |
There were Value Areas drawn on this chart which got completely shifted after rolling over to the September contracts. Why did this happen and should I simply redraw them?
[2023-06-12 14:53:12] |
Most likely your Continuous Chart is setup as a Back Adjusted chart, in which case the prices will be adjusted for previous contracts will adjust up or down in order to match to the current contract. Refer to the following: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
